inserting image in sql database.
svisveswaraiya
I wanted to insert image from thingworx to sql table (data type - img) in a column. I am using file upload widget to browse and upload image but after uploading i tried to use a insert statement to insert image but it is showing me exception :
Error executing service
Unable to Invoke Service testimg on TrainingThingWorx : null
InsertImg.pngHow can I solve this issue and insert image with full path? Please provide some help.
V Shalini.
Is there any more details in the error in ThingWorx Application Log? Is your database connected? Do you see any information when you click on "table/columns" within your service?
slangley
(To:posipova)
Hi @svisveswaraiya
If you have found a solution to your problem, please post it here and mark it as the Accepted Solution.  This will benefit others on the Community who may have the same question.
Regards.
--Sharon
