This tutorial video will walk you through the installation process for the Neo4j-based version of the ThingWorx Platform in a Windows environment. All required software components will be covered in this video.
thanks for the tutorial
i follow the same steps, tomcat installed normally but once i deploy the tingworx, tomcat stops and never start, it giver waiting for local host once i put http://localhost:8080
please advise
Hi Khalil,
Please let us know your ThingWorx version, Tomcat version as well as Java version.
If the tomcat stopped, did you get any error message in Tomcat log?
From what you discribed, I doubt that your server is running out of memory. Please check ThingWorx ThingWorx Core 7.3 System Requirements
Lily
Hi Lily,
It is Tomcat9 and ThingWorx 7.2.My laptop RAM is 12Mbyte core i7 CPU.Please advice
Hi Khalil,
As far as I know, the Recommended Minimum Hardware for ThingWorx 7.2 is:
Required Software
I suggest you to use Tomcat 8.0.33 and if still not work, increase memory to 16GB.
By the way, you also can check Tomcat Catalina.log and tomcat8/9-stderr.log. If there is any error, please let me know.
Lily
