ThingWorx data connect installation on Ubuntu
banupriyas
Hi ,
I am trying to install data connector 8 on a Ubuntu server. Did this by converting dataconnect.rpm to .deb file . ran the deb file to install connector
It runs with no errors, but the directories created are not as expected.
/opt/dataconnect/queue is not created.
Do not see anything inside logs directory as well
Please let me know if there is document about installing Data connector 8 on Ubuntu.
Banu
cmorfin
(To:banupriyas)
Hi Banupriya
DataConnect has only been QA tested on CentOS and is therefore only supported on this platform.
I would advise you use a CentOS OS for that, as it would be safer to get a functioning environment.
The Dataconnect Guide does actually give all the steps to create a VM with CentOS and install DataConnect, so you could get this running  without too much effort.
Hope this helps.
Kind regards
Christophe
