ThingWorx on-premise behind proxy
feil
Hi.
When I try to start the thingworxs plattform it shuts down before even starting with the error:
"Unable to retrieve license from FNO server because Connect to fnoauth.ptc.com:443 [fnoauth.ptc.com/52.2.0.42, fnoauth.ptc.com/3.216.245.130] failed: Connection timed out: connect - Shutting down the Platform."
I'm sure this is because I'm behind a strict corporate-proxy. How can I set up thingworxs to use this proxy to connect to the license-server?
I know there is the possibility to generate a licence-file manually, but I would prefer setting up the proxy.
PaiChung
22-Sapphire I
(To:feil)
PaiChung
22-Sapphire I
(To:feil)
Proxy may not be possible yet.
https://www.ptc.com/en/support/article?n=CS281619
feil
(To:PaiChung)
In times nearly every company uses one that's a shame and very unprofessional!
