ThingWorx source control with git clean & smudge report error
seanccc
I'm referring the article to config git :
https://www.ptc.com/en/support/article/CS267770
I've followed the last section "Updating ThingWorx with Import of a Project from Git" to config the clean and smudge,  but  run git add / git status report the error below,  the replace command doesn't work.
sed: no input files
error: external filter 'sed -i 's/lastModifiedDate=[0-9][0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9]T[0-9][0-9]:[0-9][0-9]:[0-9][0-9].[0-9][0-9][0-9]-[0-9][0-9]:[0-9][0-9]/lastModifiedDate=/g'' failed 4
could someone help on it ?
Sean
I contacted Sean and the issue was resolved with the below suggestion:
git config filter.thingworx.clean "sed -e 's/lastModifiedDate=\".*$/lastModifiedDate=\"\"/g'"
slangley
(To:seanccc)
Hi @seanccc.
Since the solution has been provided, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
