Hello everyone,
I'm using ThingWorx v9 and attempting to use the Row State formatting on the Grid Advanced widget.
However, it seems that only the first row has its state formatting applied. The rest is not done.
Is this a known issue? In previous versions, it worked without any problems.
Are you applying a fixed style or is it a state based on a field? I am already using fixed style on adv grid in 9.0 and it works perfectly fine.
Mukul Narang
Even that works for me:
I have a different style when T1 = a and default other wise and it is working. If feasible can you attach your mashup?
Hi @rnfonseca.
Have you found a solution to your issue? If so, please help our community by posting the solution here. Or if one of the previous responses helped you to find a solution, please mark the appropriate one as the Accepted Solution.
--Sharon
