The thingworx server is connected with navigate and windchill. Once the windchill server is upgraded to version 12.0, GetStructure API from PartStructureAccessAppThing is not executing.
These was the inputs provided before. Now it is not working. How to fix this ?
Please check if the version imported of the Windchill extension is correct. You can check the dependencies, compatibility here .
Sachin Sharma
In integration connector, we removed /sslClientAuth from BaseURL now services are running. But how to fix this with sslClientAuth itself in baseurl ?
