Thingworx 8.5.1 with MSSQL version 2017
vi1
I have installed Thingworx version 8.5.1 with MSSQL server 2017 as default persistence provider.
I have one doubt on thingworx database creation on SQL.
Do we need to add the name "twschema" under thingworx database?. I have not added twschema name but schema tables are created when I run the below schema command. Refer the attached screenshot for schema thingworx tables after running the schema script. I have created manually database name "thingworx".
thingworxMssqlSchemaSetup.bat -h <server> -i <server-instance> -p <port> -l <login-name> -d <thingworx-database-name> -o all
Latha
c_lowy
(To:vi1)
Yes, so right now the schema containing your ThingWorx tables is called "dbo" which is the default schema in SQL Server for a newly created database (The dbo Schema).
When you run the thingworxMssqlDBSetup.bat script you can choose to use a different schema name using the -s option as per MSSQL Database Setup for ThingWorx: Windows but this is not a requirement. If you do not set any specific value, schema "dbo" will be used.
I hope this helps.
c_lowy
(To:vi1)
Hi @vi1,
No schema needs to be created manually when setting up SQL Server for ThingWorx.
  • If you are using the ThingWorx Foundation Installer, the required steps before running the Installer are documented at the following link in the "Prerequisites for Windows with Microsoft SQL Server" paragraph : ThingWorx Foundation Installer
    • Only the twadmin user and the thingworx database are created manually
  • If you are performing the installation manually, the required steps are documented here : MSSQL Database Setup for ThingWorx: Windows
    • Only the twadmin user is created manually
vi1
(To:c_lowy)
Thank you for response. I have not created schemas manually. I have performed scripts which they have mentioned on install.
My doubt is do we need to add the schema name(<schema-name>) under database?. Currently all schemas are created under Table which I have shared screenshot in previous.
thingworxMssqlDBSetup.bat -h <server> -i <server-instance> -p <port> -a <database-admin-user-name> -l <login-name> -d <thingworx-database-name> -u <thingworx-user-name> -s <schema-name>
Latha
c_lowy
(To:vi1)
I hope this helps.
vi1
(To:c_lowy)
Thank you for clarification.
