Thingworx 8.5.4 not able to import svg-xml media entity (Error: invalid length)
IoT_Fynn
6-Contributor
Hey, I am trying to import an SVG Image into ThingWorx 8.5.4-b222.
Unfortunately I am getting following error message:
"Import failed: invalid length"
Can someone help?
Cheers Fynn
cmorfin
(To:IoT_Fynn)
Hi @IoT_Fynn
Yes it appears the way to upload svg is via dynamic content as you did.
If you check the Help Center Media page, it indicates
"Locally-stored media entities support JPEG, PNG, and BMP image types. To use other file types, refer to them as dynamic content and modify the supportedMediaEntityContentTypes parameter in the platform-settings.json file to include the desired MIME-type."
I think that follows the behaviour you are seeing.
Regards
Christophe
5 REPLIES 5
slangley
(To:IoT_Fynn)
Hi @IoT_Fynn.
Can you please provide the image so I can test it?
Regards.
--Sharon
IoT_Fynn
6-Contributor
(To:slangley)
 Hey Sharon,
thank you for your quick reply! I put the Image in the appendix. But it did not work with any svg that I tried so far.
Regards
Fynn
cmorfin
(To:IoT_Fynn)
Hi @IoT_Fynn
I am not sure how you are importing your svg file but if that is via a Media entity, currently ThingWorx does not allow it.
I'd recommend voting for this ThingWorx idea to give it more weight to be taken into considerations for future release.
Christophe
IoT_Fynn
6-Contributor
(To:cmorfin)
Oh okay. Yes i am doing it via Media entiy. There are strong hints, that you can import and svg file in TW 8.5. At least i tought so. If you have a look at the 8.5 platform-settings.json you can see this line:
"supportedMediaEntityContentTypes": [
          "image/svg+xml"
So are you sure that svg is not supported in ThingWorx 8.5?
There is a workaround. I can give the Media entity the URL of an SVG image. But for that I have to upload the svg image to my repository so I would rather use the "normal" way and upload it.
cmorfin
(To:IoT_Fynn)
Hi @IoT_Fynn
Regards
Christophe
