Mar 31, 2020 10:17 AM UTC
Thingworx 8.5.4 not able to import svg-xml media entity (Error: invalid length)
Hey, I am trying to import an SVG Image into ThingWorx 8.5.4-b222.
Unfortunately I am getting following error message:
"Import failed: invalid length"
Can someone help?
Cheers Fynn
cmorfinAnswer
Apr 2, 2020 4:20 PM UTC
Hi @IoT_Fynn
Yes it appears the way to upload svg is via dynamic content as you did.
If you check the Help Center Media page, it indicates
"Locally-stored media entities support JPEG, PNG, and BMP image types. To use other file types, refer to them as dynamic content and modify the supportedMediaEntityContentTypes parameter in the platform-settings.json file to include the desired MIME-type."
I think that follows the behaviour you are seeing.
Christophe
Support
Mar 31, 2020 3:41 PM UTC
Hi @IoT_Fynn.
Can you please provide the image so I can test it?
--Sharon
IoT_Fynn1-VisitorAuthor
Apr 1, 2020 6:44 AM UTC
 Hey Sharon,
thank you for your quick reply! I put the Image in the appendix. But it did not work with any svg that I tried so far.
Fynn
cmorfin19-TanzaniteAnswer
Hi @IoT_Fynn
Christophe
