Thingworx 9.3.4 Building Blocks -Solution Framework
SS_10154086
Hi There,
Anybody knowing from where to download the solution framework extension for TWX 9.3.4.  Download center has 'mfg1-2' for building blocks but it doesn't seem to have solution framework. If it does contain, please share the solution framework mashup name.
Sunil
You can find the latest release (1.2.0-b02) on Github: https://github.com/PTCInc/twx-solution-framework/releases/tag/1.2.0-b02
SHould be compatible with TWX 9.3.4 and 9.3.5
SS_10154086
(To:VladimirN)
Thanks Vladimir.. but that guide is not working as I checked earlier also.. Content is 'asdf' :).
