Hi All,
Is Thingworx 9.6 compatible with postgresql version 15 or can we install with that.
And i should have to go with lower versions of postgre.
Hello @Hrishabh.Sharma ,
Hope you are doing well!
Pls check the SS for your reference:
Thanks and have a good day!
Bhawna
Bhawna
Getting this error during installation.
do you have any idea about this.
Can you pls share the installation logs ? Although, I would recommend you to log a case so that you can get better assistance.
Bhawna
Where? we can check the the installation logs.
I'm trying Postresql 15.8, and This is not on your list.
It would be works or not.
In most of the scenarios, it does work. However, It is not recommended to use the lower versions.
Bhawna
Okay Bhawna.
