Thingworx Acess
Ziyad
9-Granite
Thingworx Acess
Hello Everybody
Yesterday I was working on my projects using my personal laptop because I have the free version of 3 months. and then I had some problems of "rest api failure". I didn't found any file in my (Things, datashape,thingshapes....) so I decided to restart my computer and after thingworx started to work again normally.
Today I tried to connect but I have this page and I really don't know what is the problem, the only thing I get is this page.
Could any one help me please ? I had all my projects on it and it's verry disturbing.
Ziyad
9-Granite
(To:zyuan1)
I'm using 8080 port and yes it may be a problem of tomcat also. I restarted my laptop yesterday and now Thingworx is working again hopefully. In my opinion the problem occured because my port has been occupied by another application because ports rests after a reboot in general. but I'm not sure a 100%.
Thank you for your support guys you're amazing !!
6 REPLIES 6
The URL in the screenshot corresponds to the mashup builder page for the mashup named PTC.SPC.Monitoring_MU. What happens if you navigate to just localhost:8080/Thingworx?
Do you see any error in the ApplicationLog.log file in ThingworxStorage\logs folder?
Ziyad
9-Granite
(To:rjanardan)
when try to reach the Thingworx home I get This, and when I try to reach only localhost:8080 I get error 404 page not found. I don't have acess to thingworx log application because I can not acess to thingworx
Do you think that I have a problem maybe with the configuration of my port ? Thank you verry much for your answer
zyuan1
18-Opal
(To:Ziyad)
Getting a 404 in localhost means Tomcat not working, are you using 8080 or 80 port?
And you can check in Tomcat Catalina log why it's not working.
Ziyad
9-Granite
(To:zyuan1)
If you suspect something else may be using 8080, then you can find the task as below
netstat -ano |find ":8080"
Get PID(it is 4584 in your screenshot) and run below command
tasklist |find "4584"
Ziyad
9-Granite
(To:rjanardan)
Thank you for your help, I didn't had the chance to read your message before resolving the problem. I will try for sure this commands if it happends again
