Thingworx Analytics trial Installation fails
SOLVED
Alexandrite
Hello everyone,
i have read all the other threads regarding this topic and so i tried to follow the pre installation steps mentioned here.
So i downgraded my docker version to 17.03.0 ce and my previous occuring "post installation error" does not come up any more. Instead i have the following errror
Attached you can find the log file. But the line where the error occures says:
2018/04/23 11:15:19 Post http://172.20.208.1:8080/Thingworx/Things/TW_ML_Configuration/Services/setConfiguration?method=post&...: dial tcp 172.20.208.1:8080: connectex: No connection could be made because the target machine actively refused it.
I have no idea how to set up this "target machine" to allow the connection.
Any help is appreciated very much.
Best Regards,
Dominik
Edit:
I have Sophos Antivirus running on my machine and i am not able to deactivate it since its my companies machine. Could this be the cause? I would need our admin to let me deactivate it if its the case
Re: Thingworx Analytics trial Installation fails
Hi
The error you get is
" C:\Program Files\Docker\Docker\Resources\bin\docker.exe: Error response from daemon: oci runtime error: container_linux.go:247: starting container process caused "process_linux.go:359: container init caused \"rootfs_linux.go:54: mounting \\\"/C/Users/D76C5~1.RIE/TWX-AN~1/edge-config/analytics-server.properties\\\" to rootfs \\\"/var/lib/docker/overlay2/1b442ff0d9b69cd3a4306c7fa12e16545ab9a7c0d1ec27f5341c506a635103dc/merged\\\" at \\\"/var/lib/docker/overlay2/1b442ff0d9b69cd3a4306c7fa12e16545ab9a7c0d1ec27f5341c506a635103dc/merged/maven/analytics-server.properties\\\" caused \\\"not a directory\\\"\""
: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type."
This is an error than can be caused by several things.
You will want to checkthe following:
- Docker daemon is allocated 6Gb (the default is 2Gb) - on Docker for Windows, select the docker icon in system tray > right mouse button > Settings > Advanced
- The C: drive is not shared, similar as above in Settings > Shared drive make sure C: is selected
- restart docker
However, if you are installing Analytics Trial in order to execute https://developer.thingworx.com/resources/guides/operationalize-analytics-model . I would recommend that you hold on for now.
I need to double check the status of the installer available in the Developper Zone. From what I have seen, it would seem we need a newer version to include the ThingPredictor. I need to confirm that and will post back.
Thank you
Christophe
6 REPLIES 6
Hi Dominik
It would seem to forgot to attach the log file.
Is it possible that you attach all the log files created during the installation ?
Thank you
Christophe
Ok here are the log files this time.
btw when i have rerun the installation i always get this error:
I am wondering if i am the only one with this problem. Its realy strange since docker actually should create the same environment for every user...
Edit:
I get an error when trying to upload the log files, it says the files have an invalid extensions. How can i attach logfiles?
Hi
You have a Choose Files button at the bottom of the text area when publishing a post.
Did you try this ?
I am uploading a sample log file to double check too. The file should though be zipped. the .log extension is not accepted
Christophe
Alright thank you, here is the zip folder
Hi
- restart docker
Thank you
Christophe
Its exactly like you said, im trying to redo the situation in your link.
Drive C is shared but memory allocated is 3.5 Gb. In the installation guide i believe this is not mentioned, maybe would be good to add that.
I just tried to increase the memory, but its not possible since my local machine has "only" 8GB Ram.
Anyway, thank you very much for your effort and patience!
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
