I have successfully imported the progress gauge in the below technote. How can i modify the extension so the progress ring has rounded corners? Like this:
Hi @LP_10027711.
Unfortunately, it appears your only option is to write your own widget. You might also play around to see if you can anything with CSS.
--Sharon
Hi @LP_10027711.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
