The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Thingworx Progress Gauge - rounded corners
LP_10027711
I have successfully imported the progress gauge in the below technote. How can i modify the extension so the progress ring has rounded corners? Like this:
https://community.ptc.com/t5/ThingWorx-Developers/Progress-gauge-import-failed-in-Thingworx-9-1/m-p/706541#M49877
2 REPLIES 2
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711.
Unfortunately, it appears your only option is to write your own widget.  You might also play around to see if you can anything with CSS.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @LP_10027711.
If you feel the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
