Thingworx Remote Access Client: Connection to TWX on AWS failed
drichter
Hi guys,
I'm working with the Thingworx Remote Access Client and I want to connect this with TWX which is running on AWS.
When I start a connection via the RemoteAccessClientLinker-Widget the RA-Client starts and try to connect and timed out after few secondes with the error message:
Unable to connect to Thingworx; ensure platform is available at <xxx.xxx.xxx.xxx:443> and that proxy settings are correct
Last week I try the same with a PTC-Hosted Thingworx and everything works fine. On my AWS hosted Thingworx it will not connect. Strangely it works fine with the old Remote Access Widgets.
server.xml (without all comments)
<?xml version="1.0" encoding="UTF-8"?>
<Server port="8005" shutdown="SHUTDOWN">
  <Listener className="org.apache.catalina.startup.VersionLoggerListener" />
  <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
  <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
  <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
  <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
  <GlobalNamingResources>
    <Resource name="UserDatabase" auth="Container"
              type="org.apache.catalina.UserDatabase"
              description="User database that can be updated and saved"
              factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
              pathname="conf/tomcat-users.xml" />
  </GlobalNamingResources>
  <Service name="Catalina">
<Connector      port="8080"
                protocol="org.apache.coyote.http11.Http11NioProtocol"
                connectionTimeout="20000" />
<Connector      port="443"
                maxThreads="150"
                SSLEnabled="true"
                scheme="https"
                secure="true"
                keystoreFile="${user.home}/8.5.41/conf/.keystore"
                keystorePass="KEYSTOREPASSWORD"
                clientAuth="false"
                sslProtocol="TLS" />
 <Engine name="Catalina" defaultHost="localhost">
      <Realm className="org.apache.catalina.realm.LockOutRealm">
        <Realm className="org.apache.catalina.realm.UserDatabaseRealm"
               resourceName="UserDatabase"/>
      </Realm>
      <Host name="localhost"  appBase="webapps"
            unpackWARs="true" autoDeploy="true">
        <Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
               prefix="localhost_access_log" suffix=".txt"
               pattern="%h %l %u %t &quot;%r&quot; %s %b" />
      </Host>
    </Engine>
  </Service>
</Server>
config.json (on EMS-side)
    "ws_servers": [{
        "host": "xxx.xxx.xxx.xxx",
        "port": 443
    "appKey": "xxxxxxxxxxxxxxxxxxxxx",
    "logger": {
        "level":             "INFO",
        "publish_directory": "/microserver/logs",
        "publish_level":     "INFO",
        "max_file_storage":  2000000,
        "auto_flush":        true
    "http_server":  {
        "ssl": false,
        "authenticate": false
    "ws_connection": {
        "encryption": "ssh"
    "certificates": {
        "validate": false,
        "allow_self_signed": true
    "tunnel": {
        "buffer_size":    8192,
        "read_timeout":   100,
        "idle_timeout":   300000,
        "max_concurrent": 4,
                "verbose":        false,
                "duty_cycle":     100
    "file": {
        "max_file_size": 8000000000,
        "virtual_dirs": [
            {"other":   "/microserver/other"},
            {"tw":      "/microserver/tw"},
            {"updates": "/microserver/updates"}
        "staging_dir":  "/microserver/staging"
        "auto_bind": [{
                "name": "EMSBox"
drichter
(To:drichter)
So, I think I fixed the problem. I add a domain to my ec2 where thingworx is running. Than I generate a certificate from lets encrypt for this domain. Now its look like the client can connect to thingworx. I'm not hundred percentage sure because I get a new error message in remote client:
Platform websocket error encountered. (error: Error: Hostname/IP doesn't match certificate's altnames: "IP: xxx.xxx.xxx.xxx is not in the cert's list: ")
xxx.xxx.xxx.xxx = IP of EC2.
5 REPLIES 5
slangley
23-Emerald II
(To:drichter)
Hi @drichter.
Is the hosted ThingWorx instance the same version as that running in AWS?  Is the old Remote Access client running on the same machine?  This could be a firewall issue.
Regards.
--Sharon
drichter
(To:slangley)
On AWS runs TWX 8.4.5-b102.
I try it with a other 8.4 Version (I'm not sure which exact version it was).
Actualy I use Version 8.5.0-b12.
I would rule out a firewall-problem, because with the old widget (with java starter stuff) works and this use port 443 too. And on AWS side port 443 is open.
drichter
(To:drichter)
slangley
23-Emerald II
(To:drichter)
Hi @drichter.
It sounds like the certificate that was generated was not issued with the name of the domain you are using to access your site.
Regards.
--Sharon
drichter
(To:drichter)
I can fixed that issue today. The problem was todo with settings in TunnelSubsystem. I had there entered the IP address of my EC2 instance where TWX is running. But on EMS-side I used the domain-name.
So I change "Public host name used for tunnels" in TunnelSubsystem to the domain name too.
