Thingworx Session Storage
VN_10473408
2-Explorer
In Thingworx Using window.sessionStorage storage option is only possible on client side not on the server side ? If I try to store it via javascript code will it function? The service will be excuted on mashup load.
sessionStorage is client-side only.
For server side access you will have to use Session Parameters instead.
2 REPLIES 2
Hello @VN_10473408
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
