3-Newcomer
Oct 18, 2024 5:12 AM UTC
Thingworx Session Storage
In Thingworx Using window.sessionStorage storage option is only possible on client side not on the server side ? If I try to store it via javascript code will it function? The service will be excuted on mashup load.
Rocko
RockoAnswer
Oct 18, 2024 8:14 AM UTC
sessionStorage is client-side only.
For server side access you will have to use Session Parameters instead.
Rocko
Rocko19-TanzaniteAnswer
Emeritus
Oct 23, 2024 7:18 AM UTC
Hello @VN_10473408,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
