Thingworx and Visual Studio Code with any Source Control, CI / CD
  • August 28, 2019
  • 3293 views
@htran-21 This is great!  I've been searching around to try to figure out how you're extracting the JS from the XML, but not having much luck.  Could you please share your process to extract and create the corresponding .js/.sql files?
Hi @wposner-2
Here is the code that i use to extract JS code and SQL code from the XML
docNew.XPathSelectElements($"//ThingShape/ServiceImplementations/ServiceImplementation").ForEach(codeElement =>
	var handler = codeElement.Attribute("handlerName").Value;
	var name = codeElement.Attribute("name").Value;
	if (string.Equals("Script", handler))
		// Javascript
		codeElement.XPathSelectElement("*//Rows/Row/code").WriteJS($"{entityFolderPath}/{name}.js", merge);
	else
		// SQLCommand, SQLQuery
		codeElement.XPathSelectElement("*//Rows/Row/sql").WriteSQL($"{entityFolderPath}/{name}.sql", merge);
You may need to extract mashup code, so that you would be able to track/merge UI changes
// Mashups
docNew.XPathSelectElements($"//{entityCollection}/{entityType}/Things").Where(_ => _.HasElements)
.ForEach(codeElement => codeElement.WriteXML($"{entityGroupFolderPath}/{entityName}.xml", merge)); docNew.XPathSelectElements($"//{entityCollection}/{entityType}/mashupContent") .ForEach(codeElement => codeElement.WriteJSON($"{entityGroupFolderPath}/{entityName}.json", merge));
Hope this helps!
My Bests,
Hung Tran
wposner-21-VisitorAuthor
@htran-21 Thank you!  One final question.  How are you merging your JS/SQL back in to to the XML so that it can be re-imported to TWX?  I'm really hoping this is not a copy/paste operation 🙂
Hi @wposner-2
No, everything is automatic, just perform merge task, and the final XML would be merged with the latest local/remote changes
My Bests,
Hung Tran
