Thingworx dataconnector installation
spanchal1
      I have successfully installed thingworx analytic s on one virtual machine and data connector on another virtual machine on the same virtual box.when
1.I try to access analytic by http://192.168.56.102:8080/1.0/about/versioninfo i get proper response of analytic server version 7.4
but when i try to to do the same for http://192.168.56.104:8080/1.0/about/versioninfo for dataconnetor it doesnt gives a responese.what could be the reason ,
2.also .i have my PostgreSQL server installed in the analytic virtual machine and not on the data connector virtual machine
I have set the following parameters as follows
org.postgresql.Driver
jdbc:postgresql://192.168.56.102:5432/dataconnect
dcuser
password
is that OK
and what is the data connect.transfer.uri parameter and what we need to specify for that
3.how to make a link between the thingworx repositories between thingworx foundation which is host of the virtual machine setup,where should i make those folders in the data connector ,in order to integrate with the thingworx foundation
Warm Regards,
Shubham
1 REPLY 1
cmorfin
(To:spanchal1)
It seems we have several duplicated threads with the exact same content.
This will be dealt with in Thignworx dataconnector installation
