We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I have to install Thingworx 8.5 on RHEL 7.6 with Postgresql and influxdb. I need to know where the data is stored and what size to calculate to create the file system and the corresponding partitions. My client asks me for that information. I will install as a user with few privileges. Thanks
There is an export Data function as well in Import/Export have you tried using that?
This might get you started
Just remember that Influx is only used as a persistence provider to store Stream and ValueStream data.
Thaks, PaiChung. I was reading the documents. I created a very simple Thing and saved the data to influxDB as persistent provider using a Value Stream. Now I need to export data from one instance of Thingworx to another. I exported the entity but I don't know how to export the influx data.
