Thingworx integration
karthik2
7-Bedrock
Hi all,
I want to know how to connect thingworx with qlikview/tableau/power BI.
karthik
Web Frame could be used to embed content from an external URL.
By my suggestion, I was thinking about bringing TWX data into these applications. The idea was to write a TWX service that returns the required data in the required format(let's say JSON) and make TWX REST API calls to it from your application.
You could use the ThingWorx REST API
Hi rjanardhan,
can you please provide the syntax or some sample code for that .why because i think by using webframe url is also possible to qlikview.
karthik
slangley
(To:karthik2)
Hi @karthik2.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
--Sharon
