Thingworx server login using Android App
KG_10929768
how to do basic authentication through REST API in thingworx without passing user name and password in Header
7 REPLIES 7
KG_10929768
(To:Arun_C)
Ok. But we have Login screen in android app and we want Thingworx user should login from android app. i.e we need basic authentication through API.
Is this possible with API.
1)What about all user -means every user has separate Key?
2)What about API key expiry- means we need to manually adjust date?
2)we dose not want to send login credential in header.
Hello @KG_10929768
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
You say you want basic auth, and then you say you don't want to sent credentials in the header.
This is a contradiction, as Basic Auth defines sending credentials in the header: https://en.wikipedia.org/wiki/Basic_access_authentication
Note that header information is encrypted when you use a HTTPS connection, which should be standard procedure today. So it's not going be sent in clear text over the network.
You can configure ThingWorx to delegate authentication to an external Identity Provider via OAuth -- this way your users will be able to authenticate with whatever credentials they have, and you'll be able to use one of the many OAuth authentication libraries in your Android app.
Configuring OAuth is described in ThingWorx Help.
KG_10929768
(To:Constantine)
Thanks for the replay ....
  we have to use session login and fetch the data from ThingWorx server.
Is their any other way?
Also please provide link for Configuring OAuth details.
Here's the configuration guide for configuring OAuth with PingFederate. I would expect the steps to be similar if you use another IdP like Keycloak or Auth0.
