Thingworx service to get gateway name from remote thing
rahul3
Hi
 I want to get gateway name from which remote things are binded/connected . Is there any service in Thingworx composer which can be used ?
 I am using two types of gateway :- IndustrialGateway , SDKGateway
Regards
Rahul
7 REPLIES 7
What does you mean on Gateway name?
rahul3
(To:CarlesColl)
Gateway is thing of any  Thing template of gateway type like IndustrialGateway which binds the remote thing to ingest the data from machine .
I'm not sure if that's what you are searching for, but if IndustrialGateway it's a ThingTemplate you can do a :
var gateways = ThingTemplates["IndustrialGateway"].QueryImplementingThings();
rahul3
(To:CarlesColl)
Thanks  for reply .
But service you mentioned gives the list of gateways (child remote things of Thing template "IndustrialGateway")  . I want list of remote things which are binded by  these gateways.
Ex :
As you said, if "gatewayName" is child  remote thing of  Thing template of "IndustrialGateway".
gatewayName  = ThingTemplates["IndustrialGateway"].QueryImplementingThings();
then
I want something as below
remotetihngNames =   gatewayName. serviceName_bindedThings () ;
or
gatewayname =  Thing[remotetihngNames].serviceName_parent_gateway()
When you say binded, what does you mean? LocalBinding / RemoteBinding...?
rahul3
(To:CarlesColl)
remote biniding
You should look at GetRemoteMetadata service on the RemoteThing.
