[Java SDK Tutorial] FileTransfer example and Simplethingclient, Invoke error
I did SDK tutorial. I have some error with FileTransfer example and Simplethingclient.
I have no issue with ExampleClient and Tunnel Example and I am stuck on the following error. How could I try to solve it ?
I don't know how to solve them. I have already retry configuration of eclipse three times with different project but no progress 😕
I am able to connect to the hosted thingworx server because I receve this message :
> [main] INFO c.t.s.simplething.SimpleThingClient - ****************Connected to ThingWorx Server****************
However, I have for the two example the same kind of error :
(SimpleThingClient example )
> com.thingworx.common.exceptions.GenericHTTPException: Unable to dispatch [ uri = /Things/SimpleThing_1/Services/CreateNewThing/]: Unable to Invoke Service CreateNewThing on SimpleThing_1 : Execution error in service script [CreateNewThing] :: Entity [EntityServices] does not exist
at com.thingworx.communications.client.BaseClient.invokeService(BaseClient.java:422) ~[thingworx-communications-client-development.server.build-b679.jar:na]
at com.thingworx.communications.client.BaseClient.invokeService(BaseClient.java:372) ~[thingworx-communications-client-development.server.build-b679.jar:na]
at com.thingworx.sdk.simplething.SimpleThingClient.main(SimpleThingClient.java:101) ~[bin/:na]
(FileTransferExample)
>com.thingworx.common.exceptions.GenericHTTPException: Entity SystemRepository does not exist or is not yet associated with a Thing
at com.thingworx.sdk.examples.FileTransferExample.main(FileTransferExample.java:47)
Thanks in advance for your help
