Thingworx set a custom return code and response
rbeck
6-Contributor
In a service I need to return an error with status code = 500 and return type JSON.
Actually my service returns JSON but the response I really get is "Error executing service getError. Message :: {"test":"error"} - See Script Error Log for more details." and what I want to get is just the JSON {"test":"error"}
I succeeded to have this work if I call a service on a resource but as soon as I call the service of the resource from a service of a Thing it doesn't work.
Any ideas?
Best regards
It is not possible to specify the HTML return code from within a thing service.  In the case you provided you could do something like the following:
var result = {};
if(code >= 500)
    try
        result.message =  Resources["JSONErrorResource"].GetBadRequest(
                          {content: {"plop": "error"}});
        result.status = "200";
    catch( err )
         logger.error( "The following error occured. " + err );
         result.status = "500";
         result.message = "Some Error message here";
else
    result.message = "ok";
This will return JSON in the following format:
    status:200 OR 500
    message:OK OR Custom error message OR Service response
 The calling application would then be responsible for checking the content returned for the "true" service status code and response message.
8 REPLIES 8
PaiChung
22-Sapphire I
(To:rbeck)
What does your actual code look like that sets the result when you want to return the error?
rbeck
6-Contributor
(To:PaiChung)
My service in the Thing calls this:
if(code >= 500){
	// result: JSON
var result =  Resources["JSONErrorResource"].GetBadRequest({
	content: {"plop": "error"} /* JSON */
} else{
var result = {"plop": "ok"};
 Where Resources["JSONErrorResource"].GetBadRequest is a resource I created in Java which throws a InvalidRequestException
It was a test because my main purpose remains to reply an error 500 with a JSON content and not a string "Error executing service getError..."
PaiChung
22-Sapphire I
(To:rbeck)
use a logger statement to see what is actually being generated, also maybe add a try catch because perhaps something else is happening to generate an error you aren't expecting.
rbeck
6-Contributor
(To:PaiChung)
Where do you suggest to put the log? Because in the java resource I have only one line (the throw Exception) and in the service there is no much code as you can see in my previous post.
Best regards
PaiChung
22-Sapphire I
(To:rbeck)
Just put logger.warn(result); at the very end.
Or logger.debug if you prefer that, but then make sure you change your logging level.
var result = {};
if(code >= 500)
    try
    catch( err )
else
    status:200 OR 500
rbeck
6-Contributor
(To:TravisPickett)
It is the direction we will take in the project indeed.
However, it's disappointing that we can't do this. I hope this feature will come in a future version of THX.
Thank you
slangley
(To:rbeck)
Hi @rbeck.
Please feel free to post any ideas on our Ideas page.  This will allow others to vote on it and you can monitor it's status for possible inclusion in a future release.
--Sharon
