We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
In a service I need to return an error with status code = 500 and return type JSON.
Actually my service returns JSON but the response I really get is "Error executing service getError. Message :: {"test":"error"} - See Script Error Log for more details." and what I want to get is just the JSON {"test":"error"}
I succeeded to have this work if I call a service on a resource but as soon as I call the service of the resource from a service of a Thing it doesn't work.
Any ideas?
Best regards
It is not possible to specify the HTML return code from within a thing service. In the case you provided you could do something like the following:
var result = {};
if(code >= 500)
try
result.message = Resources["JSONErrorResource"].GetBadRequest(
{content: {"plop": "error"}});
result.status = "200";
catch( err )
logger.error( "The following error occured. " + err );
result.status = "500";
result.message = "Some Error message here";
else
result.message = "ok";
This will return JSON in the following format:
status:200 OR 500
message:OK OR Custom error message OR Service response
The calling application would then be responsible for checking the content returned for the "true" service status code and response message.
What does your actual code look like that sets the result when you want to return the error?
My service in the Thing calls this:
if(code >= 500){
// result: JSON
var result = Resources["JSONErrorResource"].GetBadRequest({
content: {"plop": "error"} /* JSON */
} else{
var result = {"plop": "ok"};
Where Resources["JSONErrorResource"].GetBadRequest is a resource I created in Java which throws a InvalidRequestException
It was a test because my main purpose remains to reply an error 500 with a JSON content and not a string "Error executing service getError..."
use a logger statement to see what is actually being generated, also maybe add a try catch because perhaps something else is happening to generate an error you aren't expecting.
Where do you suggest to put the log? Because in the java resource I have only one line (the throw Exception) and in the service there is no much code as you can see in my previous post.
Best regards
Just put logger.warn(result); at the very end.
Or logger.debug if you prefer that, but then make sure you change your logging level.
var result = {};
if(code >= 500)
try
catch( err )
else
status:200 OR 500
It is the direction we will take in the project indeed.
However, it's disappointing that we can't do this. I hope this feature will come in a future version of THX.
Thank you
