Hi All,
I'm using Thingworx 7.4.
When I'm using Google Chrome
the widgets google map and Three Model Viewer are not see on Mashup.
The following are the mashup on Chrome
next picture is the same mashup in Internet Explorer 11 (11.0.40)
Can someone help me
Many Thanks
Dimitri
Can you open up the Chrome Developer console and see if there are any errors in there?
To open the dedicated Console panel, either:
Hi Petrisor,
many thanks for your suggestion.
The message on console panel in firefox browser are the following
Many Thanks
BR
Dimitri
A custom widget that you have installed does not work correctly on Chrome. This is made clear by the SyntaxError in the console log.
Can you maybe right click on CombinedExtensions.20170719_062407.js (the red line) and select open in a new tab. Then attach the results here. This can help us understand which of the widgets causes the problems.
Hi Petrios ,
sorry for my delay but Yesterday I was out of office.
In attach a CombinedExtensions.20170719_062407.js file as you requested.
BR
Dimitri
Looks like the chartWidget_ExtensionPackage that you imported was somehow messed up as it's contains invalid characters. Can you try to remove it and redownload it from another source?
Hi Petrisor,
I did the following steps :
1)I removed the package chartWidget_ExtensionPackage
2) I download chartWidget_ExtensionPackage from market Place PTC
3) I import the extension in Thingworx
4) there is the same error
inside the code CombinedExtensions.20170726_040237.js I see the following rows
BR
Dimitri
