Time Series Chart doesn't use bound values AxisMaximum & AxisMinimum
Ilya
7-Bedrock
I bound values to properties AxisMaximum1 and AxisMinimum1, but the chart doesn't reacts on data. It prefers to use manually entered values. The property YAxisMode set to "Multiple Y Axes".
Does it depend on any other property?
I am using ThingWorx 8.5.9-b494 and build in widget  timeserieschart.
Hello @Ilya,
Have you tried setting the DataField under Settings and X-AxisField ?
Thank you,
Yes, I did. These field are bound to the data (single source). Chart shows data well.
Probably I found the reason why. The properties names missing a letter 'Y'. When I opened mashup in Thinworx version 9, the properties have name YAxisMaximum1 (and it works there).
If so, can it please be fixed in version 8?
Hello @Ilya,
Would it be possible to open a case with support services with the detailed steps ?
