I have observed below errors on Tomcat logs. Is there any problem?. We have observed server was not responding(500 Unexpected error). I am not sure because of below errors. Now also observing below errors but server is responding correctly. I am using Tomcat 8.5, Azure Postgre SQL version 10,Thingworx version 8.5.1 with HA configuration.
1. SEVERE [https-jsse-nio-443-exec-10] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause java.lang.NullPointerException
2. SEVERE [https-jsse-nio-443-exec-9] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
at com.thingworx.webservices.context.HttpExecutionContext.commitResponse(HttpExecutionContext.java:515)
at org.apache.jsp.login.FormLogin_jsp._jspService(FormLogin_jsp.java:632)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:476)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:386)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:330)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:138)
at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389)
at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:208)
at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:173)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:645)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:678)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:609)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:810)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1506)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
17-Jan-2021 00:42:11.959 SEVERE [https-jsse-nio-443-exec-6] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
17-Jan-2021 00:45:37.464 SEVERE [https-jsse-nio-443-exec-3] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [FormLogin] in context with path [/Thingworx] threw exception [java.lang.NullPointerException] with root cause
Latha
Thank you for responding. I will share you the Logs.
Latha
