Tree grid advanced widget
NJ_10144761
11-Garnet
I want to pull data from database and show on the Tree grid advanced widget. Can anyone please help me to create the service.
Hi @NJ_10144761 ,
Is it any external database or Thingworx database?
If external DB, you can write service with SQL commands -  SELECT * FROM table_name and service output as infotable.
If Thingworx DB, you will be storing the data in Stream/Datatable.
In that case, you can write the service as follows.
SELECT * FROM stream WHERE entity_id = "Your stream name".
With regards
Yedukrishnan
Hi @NJ_10144761 ,
Please let me know your data storage-Stream/Valuestream/Datatable.
With regards
Yedukrishnan
Stream, I am using a database thing
Hi @NJ_10144761 ,
With regards
Yedukrishnan
