Hello, I have imported a modified google map widget extension but it does not appear in widgets, I have another modified google map widget extension but with another name, can it be a reason why the extension does not appear?
Hello @AC_9552412 ,
Pls check the following article for the same:
https://www.ptc.com/en/support/article/cs188314
Kindly let me know if you have any further queries.
Regards
Bhawna
hello, it is not the same problem, the google map extension that I have imported does not appear in the widget box
Hi @AC_9552412
This is usually a caching problem. Try clearing your browser and restarting ThingWorx.
Regards.
--Sharon
Hello @AC_9552412 ,
Sometimes this widget does not respond in Google Chrome and Firefox browser. Pls try in Internet Explorer.
Regards
Bhawna
Hi @AC_9552412.
I haven't seen this problem for a while. What version of ThingWorx are you running? Have you tried restarting Tomcat?
Note that Internet Explorer is no longer a supported browser.
Regards.
--Sharon
Hi @AC_9552412.
Did you try clearing your browser cache, then restarting your browser? Which version of the Google Maps extension did you import?
Regards.
--Sharon
Try Edge browser.
