While i am trying to create one more Kafka extention its trying to delete the current kafka extention that is not required to me can any one help what is I am doing wrong
| KafkaThingExtensionPOC:1.1.3 | ExtensionPackage KafkaThingExtensionPOC:1.1.3 upload attempted and it is not an HA compatible extension. | |
| KafkaThingExtensionPOC:1.1.3 | Cannot update existing Extension Package [KafkaThingExtensionPOC] because it is trying to remove the following Entities that are still in use: [entity: KafkaProducer, used-by: Thing : KafkaThing] |
I already have KafkaProducer i want to create new one with name KafkaProducerPOC any help appriciated
The answer is in the error messages displayed: the new Extension is trying to remove the KafkaProducer (assuming it's template), because it's no longer present in the Extension. What exactly do you have in the 1.1.3 version of your extension in terms of Templates/Things? If KafkaProducer is not in there, then the system will try to remove it when you deploy the new version.
Hi @AG_11031228 ,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
