Tutorial-Build and Deploy an Analytics Model Exercise Issue
Dai-2006
Hi, I am using offical thingworx to follow the beginner tutorial-Build and Deploy an Analytics Model.
In step 2, in tutorial, after click the connected clients, the chart with green square should be seen.
But in my exercise, I could not see the chart and it shows no data available (refer attachment).
1 ACCEPTED SOLUTION
IWO
9-Granite
9-Granite
(To:Dai-2006)
i had the same problem....
The Analytics-Server-Settings changed to "use SSL".
After unchecking these Setting everthink works fine.
In the "new Composer" you can find this setting under "Analytics-Builder" -> "Settings".
I will attach a screenshot...
8 REPLIES 8
Dai-2006
(To:Dai-2006)
Another error when using analytics builder
Status Messages
Creating copy of Configuration File...
Creating copy of Data File...
Submitting Create Dataset request...
Dataset Create Job with jobId: 94c573b8-7b98-4009-ab02-3083bfb30b03 in progress...
Dataset Create Job with jobId: 94c573b8-7b98-4009-ab02-3083bfb30b03 failed with error:
java.io.IOException: Unable to initialize FileRepository [AnalyticsUploadStorage] Unable to initialize FileRepository [AnalyticsUploadStorage] Unrecognized SSL message, plaintext connection? For support cases please provide this log tag: b49096bd-f5b8-4749-96c9-8df40f7c7041
mgoel
(To:Dai-2006)
@Dai-2006
Thank you for opening this post. Could you please response on below:
1) Which guide you are following.
2) Which version of ThingWorx and Analytics server you are using.
3) have you started the ThingPredictor agent. Is it up and running.
Regards- Mohit
Dai-2006
(To:mgoel)
1) "Build and Deploy an Analytics Model" by Jason Wyatt Published June 13,2018
2) ThingWorx 8.3.0-b349, server is official server set by vendor inside our company
3) I don't know how to start the ThingPredictor agent
Dai-2006
(To:mgoel)
The guide image was attached, hope for better understanding. Thanks.
IWO
9-Granite
9-Granite
(To:Dai-2006)
Dai-2006
(To:IWO)
Thanks a lot. Now the upload data error was solved.
Dai-2006
(To:mgoel)
Hi, mgoel,
for 3), could you give suggestion how to start the ThingPredictor agent?
IWO
9-Granite
9-Granite
(To:Dai-2006)
May it helps...
I start the agent with a simple call:
java "-Dvariables.file=file:///C:/<path_to_your_agent.jar_and_settings>/system-environment-variable.properties" -jar thingpredictor.jar server predictive-standalone.yml
If you run the actual version of the Analytics-Server the agent are already included. But both versions (included and external) are working.
The guides sometimes not actual...
