Unable to Invoke Service GetXML on ContentLoaderFunctions
BABA-SHYAM
I am seeing Unable to Invoke Service GetXML on ContentLoaderFunctions everytime I execute GetXML function of resource ContentLoaderFunctions with URL http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx/GetCountriesAvailable .
I have created one service which internally gets the xml on a particular URL. It works fine on my Home TW composer. But here in my Workstation TW composer it is causing some issue in service. So I was trying to call GetXML function directly. It is showing this error Unable to Invoke Service GetXML on ContentLoaderFunctions.
I have all visible , run time permissions in place.
4 REPLIES 4
What is the response code/error you are seeing in developer options ?
Thanks ,
Mukul Narang
PaiChung
22-Sapphire I
(To:mnarang)
Also try the url call from something like Postman to see if it works.
BABA-SHYAM
(To:PaiChung)
The same service works on other thingworx environment. URL is quite accessible using postman and other services. The issue is related to the composer itself.
PaiChung
22-Sapphire I
(To:BABA-SHYAM)
Probably need to check firewall setting?
