Unable to connect to SQL server
pchowdhury
Hi @Rocko/All
I got this block-
https://community.ptc.com/t5/Vuforia-Studio/Easiest-way-to-connect-an-SQL-database-to-Thingworx-Studio-For/td-p/529820
where there is one link to get the extension for JDBC(SQL SERVER) -  https://marketplace.thingworx.com/tools/jdbc-connector-extension is not working can anybody point me to right link?
Also, I put the JDBC driver(main one not the extension) in tomcat/lib and trying to  connect to MSSQL server by using a Database thing but not able to connect. any idea, am i doing right?
Here is the log:
[context: com.thingworx.webservices.context.HttpExecutionContext@7504795c][message: Thing [MSSQLConnection] is not running]
Thanks!
~PC
Reference:  post
Rocko
(To:pchowdhury)
Using the Database thing is the correct way, the jdbc extension isn't needed anymore AFAIK.
In your case I would try to restart the server and check if you have the right connection string.
Rocko
(To:pchowdhury)
slangley
(To:pchowdhury)
Hi @pchowdhury.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
