Unable to export any XML from ThingWorx
ntiishadhla28
2-Guest
When ever I export any Thing or Collections than getting rendering error. I have attached a screen shot. Can anyone please help us.
slangley
(To:PEHOWE)
Hi @ntiishadhla28.
Have you recently upgraded your ThingWorx instance?  If so during the upgrade process did you delete \ThingworxStorage\esapi\validation.properties?  If not, please review this article for resolving the issue.
--Sharon
Hello @ntiishadhla28
Have you done Exports previously?
What version of ThingWorx is being used?
Have you checked the logging for any error messages?
PEHOWE
We are using TW 8.4. I checked logs and found this error:
[context: com.thingworx.webservices.context.HttpExecutionContext@1b4d37e4][message: setHeader: Invalid input. Please conform to regex ^[a-zA-Z0-9()\-=\*\.\?;,+\/:&_ ]*$ with a maximum length of 2000]
The imports are working fine. Only issue with all exports
slangley
(To:PEHOWE)
Hi @ntiishadhla28.
--Sharon
slangley
(To:slangley)
Hi @ntiishadhla28.
If one of the previous responses allowed you to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
--Sharon
