Hi @slangley ,
I am not able to navigate to a new mashup using navigation in TWX 9.3.2. I tested with the mashup files in this post. Please look into it.
Kaushik
@Kaushik_22 You forgot to attach the mashup.
Other than that, I'd check a few more things to try find / pinpoint the cause...
1) What do you mean as "I'm not able to navigate to a new mashup"? The mashup doesn't open when clicking "View mashup" in the composer UI?
2) Do other / "old" mashups work?
3) If you create another "new" mashup, would it work?
4) A basic thing, you've probably done it already, but still... Is the behaviour the same in other browsers / in Incognito (Private) mode / on other machines?
Hi @DmitryTsarev ,
Thank you for your reply. Clearing the browser cache resolved the issue. I recently upgraded TWX from 9.1 to 9.3.
Kaushik
