Thingworx 9.1 adjust width of label text on value display
blacksheep
Hi! I have a large value display that is cutting off the label text at the top.  The widget is definitely wide enough but the text is not the length of the value display.  How do I extend it instead of it showing the ellipses(...)?
1 ACCEPTED SOLUTION
blacksheep
(To:slangley)
I already changed the value display widget to a label widget and now it shows all the text.
5 REPLIES 5
Is this in a custom app/mashup? The OOTB Navigate apps or LandingPage mashup are not editable.
blacksheep
(To:barko)
Yes it is a custom app.
slangley
23-Emerald II
(To:blacksheep)
Hi @blacksheep
Can you send us the mashup to see if we can reproduce it?  We weren't able to recreate it in our testing.  You can remove any sensitive information.
Regards.
--Sharon
blacksheep
(To:slangley)
slangley
23-Emerald II
(To:blacksheep)
Hi @blacksheep.
I have marked the solution to your post.  If you disagree with my choice, please let me know.
Regards.
--Sharon
