UpdatePropertyValues throws : An Invalid Property Value Was Sent To Thing Property: [null]
ahawaldar
Hello Team,
I have few properties for a thing . Lets say properties are x,y and z. A custom service is written which will set the values for x, y and z in java server side extension. What I have done is. I have created a datashape which has same property definition as that of x, y and z. From this datashape created an infotable as below
DataShape freqComponentTimeSeriesDataShape = (DataShape) EntityUtilities.findEntity("FreqComponentTimeSeriesDataShape", ThingworxRelationshipTypes.DataShape);
InfoTable valueStreamInfoTable = freqComponentTimeSeriesDataShape.CreateValues();
Next , I have added values to the infotable. When I invoke the service UpdatePropertyValues  on the thing in server side extension code it throws the error as  An Invalid Property Value Was Sent To Thing  Property: [null].
The code is as below
Thing rollingStockThing = (Thing) EntityUtilities.findEntity("RollingStockThing", ThingworxRelationshipTypes.Thing);
rollingStockThing.UpdatePropertyValues(valueStreamInfoTable);
Azim
vr-6
(To:ahawaldar)
var newEntry = new Object();
newEntry.time = new Date(T_UX*1000); // Time Stamp
newEntry.quality = undefined;
newEntry.name = "CirculationPumpPressure"; //Property 1
newEntry.value = CirculationPumpPressure; // Property 1 value
info1.AddRow(newEntry);//Add roe to infotable
newEntry.name = "DAQStatus";//Property 2
newEntry.value = DAQPowerStatus;// Property 2 value
info1.AddRow(newEntry);//Add row to infotable
Above code will update all property with same timestamp.
You need to initially add timestamp to your infotable and add other property & values.
Finally pass infotable to Updateproperty service
vr-6
(To:ahawaldar)
To use UpdatePropertyValues, infotable should have 4 field ( name, value,quality, timestamp).
name - Property name
value - Property value
quality - can be undefined
timestamp - Time
Add all your Property and Property values to infotable and pass it to "UpdatePropertyValues" service.
ahawaldar
(To:vr-6)
I guess this will update each property per timestamp. Then all the other properties will have different timestamp. My requirement is for the same timestamp update all properties i.e all properties should have same timestamp for each row.
vr-6
(To:ahawaldar)
ahawaldar
(To:vr-6)
Thanks Velkumar R
qngo
(To:ahawaldar)
