after i uploaded "Upload thing" extension on Thingworx Platform the Thingworx Builder goes down.
the error is the following:
org.hibernate.exception.GenericJDBCException: Could not open connection
Do you know why i got this issue?
I tried to reboot the system but the issue is still there.
Any solution?
Thanks in advance
Marco
Hi, Marco. Is this a ThingWorx Analytics server? Is it a new install or one that worked in the past and is just now failing?
Attach the application log(s) and we'll see if there are other errors reported. Similar reports of that
error are related to this article; see if that can help you out.
-- Craig A.
Somehow the link given by Craig seems broken, the article can be accessed at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS256240
