Updating time of a property in Thingworx using lua
mnaeem
Trying to update time of the property on thingworx using following code
ts = 1578034820000    -epoch unix time in miliseconds
local data = {}
data.value = valore
data.time = ts
data.quality = "Good"
me:setProperty(nome, nil, nil, data)
,but except time it is updating value and quality of the property.
Tried to update after converting ts into different formats, but in vain.
Thank you!
Best Regards,
Naeem
c_lowy
(To:mnaeem)
Hello @mnaeem ,
We just created the following article that clarifies this behavior and should help you with the issue you encountered : Timestamp is lost when pushing property from Lua Script Resource in ThingWorx.
Best regards,
Charlotte Lowy
6 REPLIES 6
We can reproduce this behavior and we will open a case in you name for further investigation.
mnaeem
(To:smainente)
Thank you @smainente ,
I really need assistance in this issue.
I'd be really thankful to you.
Best Regards,
Muhammad Naeem Akhtar
c_lowy
(To:mnaeem)
Hello @mnaeem ,
Best regards,
Charlotte Lowy
mnaeem
(To:c_lowy)
Thank you @c_lowy
It's really helpful in the use case asked in the question.
In another use case I'd like to update VTQ of the property using updatePropertyValues in Lua Script. I couldn't find any guide to call Thingworx services in agent (LUA EMS).
Best Regards,
Naeem
Hi @mnaeem,
Why do you need to use the updatePropertyValues service instead of of the built in property push mechanism of the EMS/LSR ? What are you trying to implement ?
mnaeem
(To:smainente)
Hi @smainente
In the following coding I have many if conditions, and I'd like to decrease lines of my code
lineToRead[i] = array of 3 entries
for i = 1, #lineToRead do
    if lineToRead[2] == "PencilCounter" then
    properties.Signal_Pencil.time = tonumber(lineToRead[1])*1000
    properties.Signal_Pencil.value = tonumber(lineToRead[3])
    log.info(p_data.name, "Signal_"..lineToRead[2].." is "..lineToRead[3])
elseif lineToRead[2] == "RPM" then
    properties.Signal_RPM.time = ........
    properties.Signal_RPM.value = ......
elseif lineToRead[2]=="I15" then
elseif lineToRead[2]=="I20" then
    ............. and so on
