I see moment.js library in libraries list of ThingWorx.
I try to use it:
const currentDate = moment();
But in this case service returns error:
"moment" is not defined
What can be a problem?
Thank you in advance.
Where you are using moment.js on a UI Extension or at Server Side Javascript? on the first case you should be able to use it, on the second not, there isn't moment.js (nor anyother) on Server Side Javascript (this is not the browser it's the Rhino Javascript engine).
yes, I tried to use it at server side.
it's strange, that we have at server side dateFormat, but don't have momentjs.
Then at server side, yes you only have the dateFormat. You can't add moment.js.
