The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi. I am trying to use the store and forward feature for sending data from kepware to thingworx. For the value stream, i use influxdb persistence provider. But, after testing, we don't find the stored data on the db. we tried using postgresql persistence provider and it works. Is there any configuration that we need to change for using influxdb? or, is the store and forward feature not supported to use with influxdb persistence provider?
Hi @ST_10591134.
How did you perform your testing? Is anything getting stored in influxdb? Are you seeing anything in the Kepware logs to indicate the offline cache is being used?
The problem may be in the influx configuration. There is an article that talks about some issues with InfluxDB which could be impacting the issue as well.
--Sharon
