I am trying to use Thingworx git extension. I used this guide: https://app-direct-www-cloudfront.s3.amazonaws.com/downloads/196081/Git_Backup_Extension_User_Guide_1.3.1.pdf
I had everything setup successfully based on the guide.
I got a problem when I tried to import entities using the Source Control Entities from Import menu:
Error executing API request message, sending error response to caller!
At the log, I got info message before the error message saying: Successfully added for import "file name"
Can you please help!
That was not the problem. We could not figure it out, but we ended up importing each folder sepretly (Things, Thing Templates, ... )
I think you may need absolute path mapping in your config.json for your FileRepository location at least your issue sounds similar to one i've seen before.
Hi @k_ibrahem.
If the response provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our Community!
--Sharon
We were trying a number of solutions. I was waiting until we get one before I mark it as a solution.
