Using Thingworx git extension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I am trying to use Thingworx git extension. I used this guide: https://app-direct-www-cloudfront.s3.amazonaws.com/downloads/196081/Git_Backup_Extension_User_Guide_1.3.1.pdf
I had everything setup successfully based on the guide.
I got a problem when I tried to import entities using the Source Control Entities from Import menu:
Error executing API request message, sending error response to caller!
At the log, I got info message before the error message saying: Successfully added for import "file name"
Can you please help!
- Labels:
Extensions
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
That was not the problem. We could not figure it out, but we ended up importing each folder sepretly (Things, Thing Templates, ... )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think you may need absolute path mapping in your config.json for your FileRepository location at least your issue sounds similar to one i've seen before.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @k_ibrahem.
If the response provided by @PaiChung answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for using our Community!
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
We were trying a number of solutions. I was waiting until we get one before I mark it as a solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
