Using the same service twice without importing it twice.
martingalaz
I have a service that I need to use n times in the mashup composer, I can import it n times but I don't find this scalable, this service return a string and receives a string parameter, is there a way to use it just after the first thing was used?
Hi Martin,
When is the Service being executed? For example, do you intend to select from a list of Things and execute the Service based on the Thing that is currently selected?
There is a Mashup parameter that is an input to the service, this service is a customized version of the GetFileListingWithLinks but only return a row and the link, with that I feed an image widget, the problem is that after feeding that I need to feed another image widget but with another resulting link, and I import the same service twice in order to make it work, is there anyway that inmediately after executing the service I order the execution again with another parameter and set the otp data to other image widget?
Martin,
Would it be possible to modify your Service? For example, if your Service returned more than one row, you could use the Repeater widget to repeat a Mashup containing the Image widget. If you could elaborate on your use case further, that would be helpful.
Adam
I don't see useful the repeater as long as I won't be putting the image widget in the same part of the mash, so I was thinking more about something like, changing the parameters on the fly.
