Hi, Team! I try to use TX composer in VM TX 12.0.1.2 rev1, but the TX simply don´t up.
The Whincill, Tomcat are Ok.
Exists a ordem to up the TX, in app shortcuts?
Anybody uses the 12.0.2 Rev, and obtain sucess?
Telles.
I keep going with studeis using the nem VM lanched last mouth
Hi @Telles ,
I am not able to understand the query exactly.
Can you please clarify your use case?
Are you referring any document? If yes, please share the document also.
Regards
Bhawna
Hi, Bhawna!
I´m use the VIRTUAL MACHINE VM TX 12.0.1.2, but the Thingworx doesn´t open. In work area, exists some shortcuts to up the Thingworx. I imagine these shortchuts have a order to execute them. What´s the order to start ?
tks.
Telles.
Hi @Telles ,
Can you please check the compatibility of the VM installed with the ThingWorx version?
I am attaching the article (System Requirements and Sizing Recommendations for ThingWorx Platform ) to do the same.
Kindly go through the article and revert back your response.
Regards
Bhawna
Hi, Bhawna.
Follow my configs.
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz 4.00 GHz
32,0 GB ram
ssd 512gb
I download another VM 12.0.2.0 Rev1, maybe this version can help me.
But I can´t find the PTCDefaultProject too.
Tks.
Telles.
