To develop a source control solution in Visual Studio, we tried to follow the steps in the below link. But we were unable to proceed to step 3. We are beginners in this so we would like to know if there is any detailed document on this. In the steps mentioned in the link there seems to be a gap in the flow between step 2 and step 3.
Please advice how to proceed.
Thanks in advance,
Shalini V.
The solution you found was published by a community member, so he will have to answer your questions.
Here is an article that may be helpful for your needs. An alternative, is the option detailed here. Note that this is not supported by PTC but may provide a solution while you work through any issues with your Source Control system.
--Sharon
--Sharon
